Old 7-Apr-2014, 4:52 AM   #13
The strip-line type balun used on many of the AD UHF antennas will tend to be close to a short circuit in the L-VHF band. I wouldn't expect much VHF signal will pass the stock balun on the DB(n)E antennas or the 91XG.
You may have better success if you use a UHF/VHF signal combiner to insert the VHF dipole into the down-lead. That would also require a separate balun for the VHF dipole.
