You installed a power-blocking splitter between the amplifier and it's power supply. This cut off operating power to the amplifier and turned it into a brick.
A common enough mistake.
If you must install the splitter somewhere in the cable run between the inserter and the amplifier, you must used a DC pass-thru splitter.
