Old 6-Apr-2014, 4:21 PM   #9
freetvplease
So here is my plan of attack to begin with.
1. Reposition the power injector in the attic and split the lines to each tv to be more equal. BTW can someone suggest a good splitter? I think the one I'm using is cheap.
2. Raise my current antenna higher and try the balun mod suggested by dmf. Next question, since the antenna will be 20ft above the roof edge will I need to add another guy wire assembly half way between the roof edge and the one near the top?
3. If those two don't gain me what I'm looking for then I'll try the angle idea dmf suggested before purchasing combo setup Ground suggested.
Along the way I'll be zeroing the scans and rescanning.
Anyway this is my plan atm. Thank you all,
John
freetvplease is offline   Reply With Quote
