Old 5-Apr-2014, 4:40 PM   #6
Ok here is my suggestion.
This reception situation is a , 100% Test , reception situation , even at 80 feet antenna height above ground.
The signal strengths of these 4 Tv stations in the direction of 100 degree magnetic compass direction are Vary Weak.
KVOS-DT , Real UHF channel 35 , (virt) virtual number (12.1) , Me-Tv and Movies.
KBCB-DT , Real UHF channel 19 , (virt) virtual number (24.1) , Shopping Channels and Estrella Tv.
CHEK-DT , Real UHF channel 49 , (virt) virtual number (6.1) , Independent Tv station.
K24IC-D , Real UHF channel 24 , , (virt) virtual number (28.1) , PBS.
Use a -->Tall<--straight tree as Tv antenna tower.
Here is a Tree Mount , http://www.ronard.com/tree_adjust.html.
Install a , Antennas Direct , DB8e , UHF channels antenna on the tree mount.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
The FM radio interference trap of the preamplifier will be in the , in/on position.
Only 1 Tv will be connected for the reception Testing.
Aim the antenna at about 100 degree magnetic compass direction.
The antenna aim direction will be adjusted for best reception.
Also , CHAN-DT , Real UHF channel 22 , (virt) virtual number (8.1) GTN.
Is at 50 degree magnetic compass direction. Test reception by aiming antenna at about 50 degree magnetic compass direction.
Rescan for channels.
I am curious , how high does the tvfool report say the reception antenna needs to be to put these Tv stations in to the , Green , Yellow , Red , reception zones. And please make and post the tvfool report/s.
KVOS. Me-Tv and Movies.
KBCB. Estrella Tv and Home Shopping.
CHAN. GTN.
CHEK. Religion.
K24IC. PBS.
CIVI. CTV2.
CIVT. CTV1.
CBUT. CBC.
______________________________________________
Here is a way to receive Satellite Tv channels for Free.
It is , FTA-ST = Free To Air-Satellite Tv.
Here is a web site to learn more.
http://www.ftalist.com.
Here is a FTA Receiver , http://www.manhattan-digital.net.
Here are some places to buy antennas and etc. in Canada.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.drsat.ca
You can subscribe to , http://www.shawdirect.ca.
Last edited by teleview; 7-Apr-2014 at 7:33 AM. Reason: Clarify information and typos.
