I'm only a few miles down rt. 522 from you. By recommendation from telview I purchased a Clearstream 4 antenna plus the vhs kit . I removed the screen off the antenna witch slows the antenna to receive signals from front and back. I receive good reception from both Richmond and Charolettsville. If you don't care about receiving channel 12 out of Richmond then you won't need the vhs kit. I don't need a preamp. I don't receive channels 16 or 27 from cville but they are just repeats of the major networks. No big loss. Hope this helps as to reception in this location.
