Old 3-Apr-2014, 7:08 PM   #3
The Digital Broadcast Tv Stations to the , South South East , are.
WBOC-DT Real UHF band channel 21 , (virt) virtual number (16.1) , CBS , FOX , Antenna Tv.
WMDT-DT Real UHF band channel 47 , (virt) virtual number (47.1) , ABC , The CW.
WDPB-DT Real UHF band channel 44 , (virt) virtual number (64.1) , PBS.
WNDC-LP Real VHF low band channel 2 , (virt) virtual number (11.1) Religion.
WCPB-DT Real UHF band channel 28 , (virt) virtual number (28.1) PBS.
WDPB and WCPB are the same PBS.
The UHF channels to the South South East are strong signal strength and easy to receive.
If the channel 2 WNDC Religion , is Excluded from reception , then all easy to receive channels to the South South East are UHF channels.
A antenna system amplifier will most likely not be required for UHF channels to the South South East.
Aim the CS2V antenna at about 169 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone compass.
The following is a best recommendation for reliable reception of channel 11.
WBAL-TV Real VHF high band channel 11 , (virt) virtual number (11.1) NBC , Me-Tv.
Is in the direction of the Trees , the signal strength is Weak , and has 2 Edge Path obstructions= hills/mountains.
So install a High Gain VHF high band antenna.
Install a , http://www.antennacraft.net.
Y10-7-13 VHF channels 7 thru 13 high band antenna aimed at about 319 degree magnetic compass direction.
As a ' Test ' to boost reception of channel 11 , connect the PCT-MA2-2P amplifier to Only the Y10-7-13 antenna.
Use only 1 of the outputs of the amplifier.
Install a UVSJ=UHF/VHF Separator/Joiner.
Model , EU385CF-1s
Connect the 1 output of the PCT-MA2-2P to the VHF input of the UVSJ.
Connect the CS2V antenna to the UHF input of the UVSJ.
And the remaining connection of the UVSJ goes to the Tv.
If you still have the other amplifier , the amplifier can be tested in place of PCT-MA2-2P.
http://www.amazon.com.
_________________________________________________________
You can also checkout this service , http://www.aereo.com
__________________________________________________________
The December 2013 Consumer Reports , page 42 , has , Practical , Useful , Informative , information about Internet Streaming Boxes and Streaming Services.
