Old 3-Apr-2014, 4:23 PM   #15
BostonButterfly
StephanieS: I understand what you are saying. By looking at the specs of the DB8E against my Tvfool report, it looks like the 8E would be overkill. No? If I look at the UHF stations in the providence direction, either green/yellow/red on the report, it looks like there is only one station over 30 miles away. I'm wondering if two separate DB2e's would work just as well (pointed in the directions you mentioned)?
In thinking this all through, I've been ignoring any stations in the grey section of the report. If you're saying that the DB8E will pick up those stations as well, then I understand your recommendation of the 8E. Although, almost all of those stations are beyond the 70 miles range that the 8E specs show.
thanks!
BostonButterfly is offline   Reply With Quote
