Old 3-Apr-2014, 7:34 AM   #4
WLEF-Tv , --->Digital<--- UHF channel 36 , PBS.
K31GH , --->Analog<--- UHF channel 31 , FOX. http://en.wikipedia.org/wiki/KQDS-TV.
Are easy to receive.
Above the Peak of the Roof install a , http://www.antennacraft.net.
U4000 , UHF antenna aimed at about 326 degree magnetic compass direction.
A antenna system amplifier is not required for , 1 , 2 , 3 Tv's connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
The Tv stations at , 170 , 329 , 330 , degree magnetic compass direction are Very Weak Signal Strength , have 2 Edge Path obstructions=hills and mountains and are 72+ miles distant.
Reliable reception with a Big Antenna and a preamp , at 30 feet antenna height will most likely not happen.
Also the provided tvfool report says , resolved to block street level only and may not represent the actual reception situation.
To see if signal strengths improve with higher antenna heights and the exact location of reception.
Please make and post with the Exact address , 4 more Tvfool reports , 40 , 60 , 80 , 100 , feet antenna heights above ground.
Last edited by teleview; 4-Apr-2014 at 8:28 PM. Reason: Clarify information and typos.
