Old 3-Apr-2014, 4:51 AM   #3
The provided Tvfool report shows -->Many<--Easy To Receive LOS= Line Of Sight Tv stations.
Above the Peak of the Roof install a , http://www.antennacraft.net.
HBU11K antenna aimed at about 281 degree magnetic compass direction.
A antenna system amplifier is not required.
The Tv/s Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Do not channel scan for only Analog Tv channels.
To Prove Reception connect a NEW Continues length of coax to the antenna and run the NEW Continues length of coax through a open door or window direct to the Tv.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 3-Apr-2014 at 7:36 AM. Reason: Clarify information and typos.
