Old 3-Apr-2014, 1:30 AM   #4
98mystique2
Reception of WGN will be very tricky because WGN shares channel 19 with WMTV, but WMTV is 14 db stronger than WGN. To pick up WGN you will need to stack two long yagis exactly 51 inches apart. See www.hdtvprimer.com/antennas/ganging.html for the explanation.
aren't yagi's quite directional and at 138 degrees difference from the signal i'd be ok?
98mystique2 is offline   Reply With Quote
