The Current Tv channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has channels in the , VHF high band and UHF band , in the Green and Yellow reception zones of the Tvfool Digital Current Plus Pending Applications Included Channel List and Radar Plot Map.
The Tvfool channel list and and radar plot map shows the , Real Channels that are transmitted and received and also shows the , (virt) virtual numbers.
----> (virt) Virtual Numbers Are Not Real Channels even if the virtual number is the same as the Real Channel.
Tv antennas only receive Real Channels.
The HBU11k antenna is desinged to receive the , UHF and VHF high band channels.
Directional antennas such as the HBU11K antenna receive the best in the forward direction , a little less at front angles to the antenna , less at back angles to the antenna , less at the back of the antenna , and receive the least signal on sides of the antenna.
If you look at the Tvfool radar plot and place a picture of the HBU11K antenna on the radar plot and aim the HBU11K antenna at about 347 degree magnetic compass direction you will see that the Tv stations in the Green and Yellow reception zones are at , front , front and back angles and back of the antenna with no Tv stations on the sides of the antenna.
The Tv stations in the Green and Yellow reception zones will be received.
Here is a Clear and Simple Truth.
Attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Yes you can start with the HBU11K antenna in the attic.
If reception situations happen in the attic that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic , then move the HBU11K antenna to Above the Roof.
Reason: Clarify information and typos.
