Old 2-Apr-2014, 6:35 AM   #2
A Simple reception situation.
Install a , http://www.antennacraft.net.
HBU11K antenna aimed at about 347 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
The HBU11K antenna will be installed Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of reception.
The directions of reception are , North , North West , South West , South.
Avoid trees and other obstructions in the directions of reception.
The closer obstructions are in the directions of reception , the more disruped the reception will be.
The further obstructions are away in the directions of reception the better reception will be.
The Reception signal strengths are Very Strong at your reception location.
-->MANY<--Digital Broadcast Tv Stations/Channels will be received.
A antenna system amplifier will not be required.
The coax from the antenna will not be connected to any other coaxes that have any Cable Tv services or internet services or phone services.
Do not connect the coax from the antenna to satellite system coax.
The December 2013 issue of Consumer Reports , page 42 , has a Practical and Useful and Informative Article of Internet Streaming Boxes and Internet Streaming Services such as and not limited to , HULU+ and NetFlix.
