Old 2-Apr-2014, 1:36 AM   #2
A Simple reception situation.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of reception , West , North West , North , North East , East , South East.
Install a , http://www.antennacraft.net.
HBU11K antenna aimed at about 284 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Install a , Levtion , 47690-6 , 6 way splitter.
Before the input of the splitter install a , Winegard , LNA-100 Boost amplifier.
http://www.amazon.com.
Absorbing and blocking reception.
The Best Practice for Reliable Reception is to install the , HBU11K antenna , at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv's Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu.
DO NOT channel scan for only Analog channels.
