Old 2-Apr-2014, 12:42 AM   #3
The tvfool report is not showing any antenna height above ground.
The Signal strengths of the direction of Richmond are Weak , and the Signal strengths of the direction of Charlottesville are Very Weak.
Do not delete the first Tvfool report that shows no antenna height above ground.
To see how much signal strengths improve at higher antenna heights above ground.
Please make and post 2 more Tvfool reports use your exact address and make the antenna heights 25 and 40 feet above ground.
