Old 1-Apr-2014, 11:38 PM   #2
Tower Guy
The stacker would do OK. Also consider the HD 7698P or HBU-44. Aim at 136 degrees. To try for a second group of stations consider a second antenna such as the DB8 or 91XG. Use an A/B switch to select which antenna to use. You'll probably want a preamp. The cheaper TVPRAMP-1 would be fine.
