Your other post has trouble shooting information.
The Tv reception signal strengths at your location are Strong Signal Strengths.
I did communications prewire and postwire in residential and business buildings for many years.
The coax wiring in and on a typical 2,600 square foot home will not be long enough to cause reception problems at your location for reception of the Tv stations in the Green and Yellow reception zones of the Tvfool report.
A antenna system amplifier Is Not Requird.
Trying to use a antenna system amplifier to Force Signal Through defective wiring will cause more problems.
