here is a link to a comparison of antennas, including both the CM and AD.
http://www.hdtvprimer.com/ANTENNAS/comparing.html
I am fairly certain these are original / unmodified.
The differences are channel dependent and on the order of just a couple of dB at most. I expect that you would see little difference changing to the 91XG unless the 'hack' you mentioned has reduced the performance of your CM antenna. If I understand you correctly, the left and right bays of your antenna are joined using two baluns and a reversed 2-way splitter. If so, you could easily be loosing 4 dB or more signal as it passes through those components.
