The available signals are plentiful and strong. The C2-V should be doing well if it has a reasonably clear view toward Mt. Wilson.
I tend to think your diagnosis is quite possibly correct... But, have you tried connecting the antenna to one TV at a time using just a single new cable?
You may also want to try installing an FM trap, which would reduce the potential for a powerful FM station causing trouble with TV reception. (Some tuners are less able to deal with FM interference.)
