Old 31-Mar-2014, 2:58 AM   #6
bid74
Hi Teleview and ADTech,
I worked on this over the weekend. A combination of both of your suggestions has gotten this working for the most part. I changed out the splitter and since I had an indoor/oudoor 4-way amplifier that provided a reasonable gain I used that instead of a splitter. This immediately solved the issue with the TV that had the 50 foot cable run. However, that TV could not get channel 7 so I tried the Double Rescan. That did not work so I went outside and adjusted the antennae to 356 degrees and after some trial and error I have over 100 channels on two TVs and 67 channels on the TV with the 50 foot run. I have all the channels I wanted on all 3 sets so that is good.
I did not ground the amplifier so my question is since things are working do I leave that alone or is it still required to ground the amplifier and what is the risk if I don't? If so, where do I ground it as the amplifier is under the antennae mast against the outside wall of the house. I could ground it to the antennae base, the wood itself under the guttering, or to the guttering. Let me know.
I did not change out any cables as that will be the next step if the system starts to become unstable.
Thanks to both of you for your help.
bid74 is offline   Reply With Quote
