Old 29-Mar-2014, 6:41 PM   #9
Preamps are mostly for providing enough signal for Long runs of coax and multipul splitter/splits.
You do not have Long runs of coax and multipul spliter/splits.
Use the , 10G201 preamp.
Yes I have responded to the the 40 and 60 feet antenna heights above ground , my response has appeared before the 40 and 60 foot links.
The Tv stations of the other direction can be received.
Turn the Tv antenna to that direction and scan for channels.
A easy way to receive Tv stations of both directions is to install a second antenna , and coax that is not connected to the other antenna and coax.
And connect a Stand Alone Digital Tuner.
The Stand Alone Digital Tuner is connected to the Tv.
Here are some stand alone Digital Tuners.
http://www.epvision.com.
http://www.channelmasterstore.com.
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
