Old 29-Mar-2014, 7:22 AM   #3
The Current Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Tv channels in All 3 Tv Bands.
The tvfool Channel List and Radar Report shows the , Real Channels that are Transmitted and Received, and the , (virt) virtual number.
The virtual number is Not a Real Channel , even if the virtual number is the same as the Real Channel.
Antennas are selected for reception of the Real Channels.
A All Channel Antenna is recommended for your reception location.
Some of the Tv Stations Are Weak Signal Strength at your reception location.
I Do Not recommend a Tv antenna in the attic , Yes you can start with a Tv antenna in the attic.
If reception situations happen in the attic that are not resolvable with antenna aim and location adjustments in the attic then move the Tv antenna to Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , North West , South South West , East South East.
Install a , http://www.antennacraft.net.
HD1200 All Channel Antenna Above the Peak of the Roof.
Aim the HD1200 antenna at about 339 degree magnetic compass direction.
With the HD1200 antenna aimed at about 339 degree , the Strong Signal Strength , WMGM-Dt and W48DP-D , will be received through/at the back angles of the HD1200 antenna.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 10 dollars.
10G201 preamplifier.
The FM radio interference trap will be in the in/on position.
Here is a 6 way splitter , Levition model 47690-6 .
All parts of the 10G201 preamplifier , the power supply/power injector , and the preamplifier , must be connected before the input of the splitter , because the splitter is non power passing , so their is no back feeding of DC power from the preamp power supply out to the Tv locations.
http://www.summitsource.com
http://www.ronard.com.
Here are some alternatives to HD HomeRun , etc. .
http://www.epvision.com.
And , http://www.channelmasterstore.com , has Receiver/Recorders.
