Old 28-Mar-2014, 10:49 PM   #2
The Current Real Broadcast Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable channels in All 3 Tv channel bands.
The tvfool channel list and radar report shows the , Real Channels that are transmitted and received and also shows the , (virt) virtual number.
The virtual number is Not a Real Channel , even if the virtual number is the same as the Real Channel.
Install a , http://www.antennacraft.net , HD850 ALL Channel Antenna above the peak of the roof in such a manner that the roof and building do not , obstruct , impeded , block , reception in the directions of , South , South East , East , North West.
Aim the HD850 antenna at about 165 degree magnetic compass direction.
The 165 degree is a in between aim direction for the Tv stations to the , South , South East , East.
And the Tv stations to the North West will be received at/through the back angle of the HD850 antenna.
The closer trees and outer buildings are in the directions of reception , the more the reception will be disrupted , the future the trees and buildings are away the better reception will be be.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
The FM radio interference trap of the 10G201 preamp will be in the in/on position.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2218) .
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch , 1 and 3/8 diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe , the price is low dollars at about 10 dollars.
http://www.amazom.com.
http://www.summitsource.com.
Last edited by teleview; 30-Mar-2014 at 4:51 AM. Reason: Clarify information and typos.
