Tvfool channel list and radar report shows the Real Channels that are transmitted and received and shows the (virt) virtual numbers.
The virtual numbers are Not a real channel , even if the virtual number is the same as the Real Channel.
WNBC , NBC , is Very Weak signal strength.
Is WNBC Real UHF channel 28 , virtual number (4.1) , NBC , being received and is it being received reliably??
The UHF channels of 14 thru 51 are effected more by the obstructions of trees and other obstructions.
Also the UHF channels at the reception location can have hot spots and weak spots signal strengths.
Often antenna aim tweaking and raising the antenna height and lowering the antenna height can move the antenna out of a low signal spot.
Some times just changing the antenna aim a few inches will do it.
Some times raising and lowering the antenna a few inches will do it.
Some times moving the antenna location a few inches will do it.
Some times the antenna will need to be moved to a different location.
Some times it takes a Greater Degree of antenna adjustments to have reliable reception.
Reason: Clarify information and typos.
