Gain is not the 'be all and end all' factor to consider when selecting an amplifier. You also need to consider the possibility of overload due to the total amount of signal input to the amplifier.
The TVPRAMP1R and the 10G221 are both capable of handling a mix of strong signals. The 10G222 is described by Antennacraft as, "Best used in deep fringe areas where all signals are weak." Your situation doesn't quite qualify as 'deep fringe'. You should not need the extra 7 dB of gain anyway.
If Solid Signal does not have either of the suggested amplifiers, try Radio Shack... Amazon was offering the TVPRAMP1R for less than $22 when I checked a few moments ago.
