Hi AdTech,
Thanks so much for the prompt response. I will check the KGO broadcast I am receiving. For the splitter, do you have a make/model you recommend? If not, let me know what characteristics I should look for. I need at least three outputs and I would need to know what frequency range it should go across and the acceptable losses at each output and if you have a preferred manufacturer and any other characteristics I should keep in mind.
Thanks.
