1. Check to see which KGO broadcast you're receiving. They simulcast on real channels 7 & 35 but from different locations. You may need to access a diagnostic menu to get this bit of info. The remedy will be different depending on which broadcast is being received.
2. Replace the Directv splitter with a standard splitter. Use ONLY the coaxial cable form the Directv install.
3. If necessary, raise, lower, or move horizontally in some direction to find a better spot. The first and most convenient mounting location is rarely the best available.
