Old 2-Dec-2010, 3:07 PM   #6
Tower Guy
Originally Posted by mel063 View Post
I would like to get a good indoor antenna, so I don't have to keep going outside and turning the antenna.
If you go down the path of indoor antennas expect to be just as frustrated and disappointed as going outside to turn the antenna. There's no indoor antenna sold that will pick up FOX on channel 8 with a NM of 9.9 db nor channel 43 with a NM of 7.8 db.
I'd suggest a 7-69 (HD-7696P) aimed at ~330° with an AP8700 preamp. You should not have to rotate the antenna. To get two FOX stations add a VHF high band (Y10-7-13) aimed at 94° and a Jointenna for channel 8.
