Old 25-Mar-2014, 9:10 AM   #2
KGO also has a repeater transmitter UHF channel 35 , at 31 degree magnetic compass direction.
A In Between aim direction for the antenna is 356 degree magnetic compass direction for reception of the groups of Tv stations to the , North West , North , North East , South East.
The satellite installation people often do a very poor job of putting connectors on the ends of coax and often do something to the coax , bending at extreme angle , twisting the coax , pulling and jerking the coax , cutting the coax , putting staples and nail and screws in the coax , and etc. .
Also do not use any of satellite system connection devices , such as and not limited to , multi-plexers , multi-switches , splitters , couplers , amplifiers , power injector/power supplies and etc. .
To Prove reception.
Connect a New Continues length of coax to the antenna and run the New Continues length of coax through a open door or window , direct to each Tv , 1 at a time.
Digital Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf.
To further prove reception.
Connect a New coax to the antenna and connect the coax to a , common standard splitter , that has the correct number of outputs to go to each Tv location and run coax from each output of the , common standard splitter , to each Tv location.
The coaxes will run through the inside of the building as a temporary connection situation.
Not using any of the satellite system , coax , splitters , or any other satellite system devices.
How is reception now??
Last edited by teleview; 26-Mar-2014 at 2:22 AM. Reason: Clarify information and typos.
