Old 22-Mar-2014, 7:56 PM   #9
Signals with predicted NM (noise margin) values of -10 dB and lower are going to be quite difficult to receive reliably.
WTAJ & WVIR are using the same real channel, CH-32. the other signals are also beset by adjacent and co-channel interference issues.
I won't tell you 'not to try', but rather, 'have realistic expectations'. If you get reception of any of the call signs you've listed, it will likely be dependent on atmospheric conditions occasionally providing favorable DX propagation conditions.
If I were to try this, I'd either use a DB8E & TVPRAMP1R or a custom built array... perhaps a quad-stacked 5 or 6 wavelength Rhombic.
http://forum.tvfool.com/showthread.php?t=2865
Last edited by GroundUrMast; 22-Mar-2014 at 8:51 PM. Reason: link to DIY rhombic designs.
