Old 22-Mar-2014, 6:22 PM   #5
To improve the reception of WCES channel 6 , aim the antenna at WCES at about 244 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Rescan for channels.
Your reception location has receivable Tv channels in All 3 Tv bands.
UHF band channels 14 thru 51.
Please note that the VU190 All channel antenna is not the best antenna for your reception situation.
Yes it is true that a All channel antenna receives All the channels.
And Yes it is true that the VU190 is a All channel antenna.
However the VU190 is a Very Large Directional antenna and as such , is a Very Directional Antenna in the forward direction.
Your reception location has Tv stations in more then one direction.
The directions of the Tv stations are , North , North West , South West , South East.
No I Do Not recommend a antenna rotator to aim the VU190 in different directions.
Antenna rotation Is Not channel surfing friendly , must wait for antenna to rotate.
Antenna rotation Is Not channel recording friendly.
And their will be , Domestic Situations , about the direction the antenna is aimed.
For reception at your reception location I recommend a Combination of 2 antennas.
Antenna number 1.
Install a , Antennas Direct , DB8e UHF antenna , aim 1 panel at about 127 degree magnetic compass direction.
Aim the other panel of the DB8e antenna at about 265 degree magnetic compass direction.
Antenna number 2.
Install a , http://www.antennacraft.net.
CS600 , VHF low band , VHF high band , antenna aimed at about 260 degree magnetic compass direction.
The CS600 is installed about 3 feet below the DB8e on the same mast pipe.
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8s diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast.
Connect antenna number 1 and antenna number 2 together with a , EU385CF-1s , UHF/VHF combiner.
Connect the DB8e antenna to the UHF connection of the combiner.
Connect the CS600 to the VHF connection of the combiner.
The remaining connection of the combiner is connected to the , Winegard LNA-100 Boost amplifier.
The LNA-100 is connected Before any splitters.
As I stated before.
The questionable and defective coax and questionable and defective splitter/s situation must be corrected.
And non correct coax wiring situations needs to be corrected.
Use splitters that have only the number of outputs that are required.
Every time a split takes place the signal strength is reduced.
Extra splitter outputs that are not connected to any location reduce signal strength needlessly.
Installing antenna/antennas in the attic is , asking for reception problems.
As to the converter box.
A Digital to Analog converter box , Receives the Digital Signal of WCES channel 6 and Converts/Changes the Digital signal to a Analog signal.
