Old 20-Mar-2014, 7:42 PM   #6
For better reception a outdoor above the roof antenna your reception location is a , http://www.antennacraft.net
HBU11K antenna aimed at about 160 degree magnetic compass direction.
Install the HBU11K antenna above the roof at a location that reception to the , South South West , South , South East , East , East North East , is not , obstructed , impeded , blocked , by the roof and building in those directions.
Also , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception in the directions of reception.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
With a outside antenna , a antenna system amplifier is most likely not required for , 1 , 2 , 3 , Tv locations connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
The Antenna Craft web site shows sellers of Antenna Craft antennas in Canada.
http://www.antennacraft.net.
One of the places is , http://www.trentondistributors.com.
Here is another place to buy Tv reception supplies in Canada.
http://www.saveandreplay.com.
