Old 20-Mar-2014, 7:09 PM   #2
StephanieS
Hello Zach,
The mohu sky. Hype. You pretty much nailed this antenna's claim to fame. Any time you see an antenna bragging about having an amplifier built into the antenna - run. In reality, instead of using elements to create gain, they are just doing it on the cheap and amplifying the signal. In the case of Sky, it's a single UHF element that has a amp hooked to it! So, it's not going to do well with weak signals or signals that are 1 and 2 edged terrain obstructed. You require an antenna with gain and weak signal capturing ability.
First suggestion - dump the sky. Return it if you can.
Second suggestion. Go buy a quality antenna that is designed for the 2-edged conditions that you have from Pittsburgh. A candidate I might jump for would be an Antennacraft HBU33. You can find it here: http://www.antennacraft.com/Antennas/AntennasHBU.html and here: http://www.solidsignal.com/pview.asp...na-%28hbu33%29
Orientate to magnetic heading 335.
I'd have a reasonable expectation to see everything from Pittsburgh in signal strength down to WPGH FOX.
Cheers.
