Old 20-Mar-2014, 6:18 PM   #6
The Tv signals reception is Very Weak Signal Strengths at your reception location and the tvfool channel list is also showing , 2 Edge Path , Obstructions= Hills/Mountains.
The directions of reception at your location are , South West and North West.
The Main Group of Digital Broadcast Tv Transmitters are to the South West.
It is Important to avoid , tress and tree leaves , plants and plant leaves , in those directions as much as possible.
The closer the trees the worse reception will be , the further the trees are away in the directions of reception the better reception will be.
Some and not all Negative Disruptive Effects are.
Absorbing and Blocking Reception.
Multi-Path Reflections Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the HBU55 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions including your own roof and building.
