Old 20-Mar-2014, 5:34 PM   #5
If we were neighbors, you'd see a large antenna or combination of large antennas above my roof or even on a tower. The signal conditions in this case are simply too weak to expect much from smaller solutions.
The Clear Stream 5 + DB8E + RCA TVPRAMP1R are the most compact solution I can think of.
I would also consider alternates such as the 91XG (sub for the DB8E) and the Antennacraft Y10713 (sub for the CS5).
Single combos such as the HBU-55 and Winegard HD7698P are also valid candidates to consider.
