Old 20-Mar-2014, 1:35 PM   #3
elmo
Welcome Phinr! I see no need for two antennas. There are plenty of good UHF/VHF antennas for your situation. Looks like everything you need is coming at you from SSW, nice and strong too. Regardless of strength, you want the clearest line of sight you can get. Trees, walls, etc will impact your reception. Trees tend to move and cause the most pain when they start waving at you. Outdoors is always best. With strong signals, you may be able to do an attic mount too. It's not optimal but easily checked out before making a permanent install. I'd look at the HBU-11 or the ANT-751. Either of those pointed at about 200 deg on the compass will do the trick. You can make use of existing coax as long as 1) it's not in use for ANYTHING now, including internet and 2) you remove all existing equipment, splitters, etc that you don't need. If you need splitters, get exactly what you need; ie, don't use a 4 way when you need a 2 way.
