Old 20-Mar-2014, 8:50 AM   #2
A Simple reception situation.
Install a , http://www.antennacraft.net.
HBU11K antenna above the roof in such a manner that reception is not , obstructed , impeded , blocked , in all directions.
The Main group of Digital Broadcast Tv Stations/Channels are to the , South.
Aim the HBU11K antenna at about 200 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
Avoid aiming the antenna into close trees.
And close trees in other directions are not good for reception.
Can also buy the HBU11K antenna at , http://www.amazon.com.
A antenna system amplifier will most likely not be required for 1 , 2 , 3 , Tv's connected.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels.
Do Not channel scan for cable tv channels.
Go into the Tv Channel Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels~.
Last edited by teleview; 23-Mar-2014 at 7:45 AM. Reason: Clarify information and typos.
