Old 20-Mar-2014, 1:03 AM   #3
billw
Thanks for the quick reply and the advice. I was just looking at the RCA ANT-751R antenna on Amazon. It looks like I can bolt it to the side of the house. Will mounting it up by the eave of the house be a problem? That should put it about 10 - 15 feet below the tree tops. If I understand correctly I shouldn't need an amplifier for the RCA antenna, only if I try to pick up the ION station that's 30+ miles away with the DB8e. The cable run will be about 35 - 40 feet from antenna to tuner.
billw is offline   Reply With Quote
