Old 20-Mar-2014, 12:37 AM   #2
Trying for indoor reception was worth the effort... But I'd step up to an outdoor antenna. Consider an RCA ANT-751R pointed at the 172° - 173*° group of signals.
If your antenna is only connected to the tuner of your HTPC, then adding the weak signals from the NE is not that complicated... Consider adding a second antenna and tuner to the system. I'd use an Antennas Direct DB8E facing 67°... Terminate the antenna in a SiliconDust HDHR3-US tuner. Use a wired connection (CAT-5e) between the tuner and HTPC. If the cable run from the DB8E to the tuner is more than 20', add an RCA TVPRAMP1R at the antenna.
