Old 19-Mar-2014, 11:45 PM   #4
WZTV-DT , Real UHF channel 15 FOX , should be received , no problem.
Did you do the Double Rescan??
Some times a antenna can be in a dead spot for reception of a Tv station channel and moving the antenna up or down can move the antenna out of a dead spot.
And their is the situation that , WZTV , might be off the air because of some type of trouble.
A call to the Tv stations Engineering department will find out if any problems.
If I were to install a antenna at your location the antenna would be a , www.antennacraft.net , HD1200 All channel antenna.
The advantage of a All Channel Antenna is , if one of the WTVF transmitters , 5 or 25 , is down , then WTVF will still be received.
Last edited by teleview; 21-Mar-2014 at 10:54 PM. Reason: Clarify information and typos.
