The Current Broadcast Tv Stations/Channels that are being Transmitted and Received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your reception location has receivable Tv Stations/Channels in all 3 Tv bands.
The HDB8X is a UHF channels 14 thru 51 design antenna.
Because you have ask about the HDB8X UHF antenna , I suspect you have been in contact with solidsignal.
What solidsignal is now doing to people.
It is not just you , many others are coming forward with solidsignal recommended antennas that are not correct for the reception situation.
solidsignal was the #1 place I sent people for antenna and reception devices.
Now soidsignal is pushing antennas that are designed for profit only.
solidsignal has Betrayed the public trust.
I am Very Angry.
Now I Do Not recommend solidsignal.
Other sellers also sell a variety of antennas.
If you will like to Reduce the Number of Digital Broadcast Tv Stations/Channels that can be received.
Then Yes you are free to install a antenna in the attic and install any antenna that is recommended.
Reason: Clarify information and typos.
