Old 19-Mar-2014, 3:33 PM   #6
TheNuke
Thanks to all three of you for the responses, I appreciate it.
Tele:
Here are the two reports from 40 and 60 feet.
Tony:
Thanks for detailing both suggestions. It looks like there is a $50-100 difference between the two options and a difference in form factor as well. Based on the new reports do you lean one way or the other? Again, function is the priority over form and cost. Within reason of course.
Stephanie:
Thank you for the suggestion of adding a pre-amp. We are looking into possibly mounting the antenna to the roof of the detached garage. That might give us the height we are looking for, but requires a longer coax run. I'd estimate the run at 75-100 feet. There is currently only one TV, but will likely be two in the future. Without doing any research, it sounds like a pre-amp would be a good investment based on that.
TheNuke is offline   Reply With Quote
