Old 19-Mar-2014, 5:12 AM   #5
Thumbs up
40 and 60 feet help a little , however installing the antenna above roof clear of obstructions will most likely get the Tv stations and can always go higher if required.
For reception of the South East Group of Digital Broadcast Tv Stations/Channels.
WBAY-DT , Real UHF band channel 23 , virtual number (2.1) , ABC , LWN Live Well Network.
WLUK-TV , Real VHF high band channel 11 , virtual number(x) , FOX.
WPNE-TV , Real UHF band channel 42 , virtual number(x) , PBS.
WFRV-DT , Real UHF band channel 39 , virtual number (5.1) , CBS.
WCWF , Real UHF band channel 21 , virtual number (14.1) , The CW.
WGBA-DT , Real UHF band channel 41 , virtual number (26.1) , NBC and Me-Tv.
I recommend install a , http://www.antennacraft.net.
HBU44 antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the direction of , South East.
Aim the HBU44 antenna at about 143 degree magnetic compass direction.
Can also buy the , HBU44 antenna at , http://www.amazon.com.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
Can also buy the 10G201 preamp at http://www.amazon.com
Buy the , HFS-2D and HFS-3D , splitters at , http://www.amazon.com , or , http://www.hollandelectronics.com.
Instal the , ronard(911) , 5 foot tripod antenna mount.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has , 10 foot 6 inch lengths of , TOP RAIL , chain link fence , PIPE , that makes good antenna mast pipe and is low dollars about 10 dollars.
The HBU44 antenna can also aimed at the , West North West Group of Digital Broadcast Tv Stations/Channels , to Test reception.
Aim the HBU44 antenna at about 289 degree magnetic compass direction.
And Rescan for Digital Broadcast Tv Stations/Channels.
W26EE-D , Real UHF band channel 26 , virtual number (x) , Religion.
WSAW-TV , Real VHF high band channel 7 , virtual number (7.1) , CBS and MyNetwork.
WAOW , Real VHF high band channel 9 , virtual number (x) , ABC and The CW and This Tv.
WHRM-DT , Real UHF band channel 24 , virtual number (20.1) , PBS.
WFXS-DT , Real UHF band channel 31 , virtual number (55.1) , FOX and Me-Tv and RTV Retro Tv Network.
Last edited by teleview; 30-Mar-2014 at 3:35 AM. Reason: Clarify information and typos.
