Old 18-Mar-2014, 9:59 AM   #4
WRUF-LD , Real VHF low band channel 5 , virtual number (10.1) is Strong Signal Strength at 39.8NM(dB).
Is LOS=Line Of Sight reception.
And the transmitter is Only 8 miles distant.
WRUF will be received buy the , ANT751 or HBU11K antennas.
I have looked up what networks are on all the receivable Tv stations and if required I can list them all.
The information can be found by typing Variations the Tv stations call signs in the google or yahoo search boxes.
Here is a example.
wcjp-dt , wcjp , wcjp tv , wcjp-tv
The 2 web sites that will be found that have the Most Practical and Useful information are , wikipedia.org and rabbitears.info .
Here is a example.
http://en.wikipedia.org/wiki/WCJB-DT2
WCJP-DT , has ABC and CW and CW+.
The CW is no longer on WFXU.
The Digital Broadcast Tv Stations/Channels that are listed in the Tvfool Current Plus Applications Included Channel List and Radar Report are Strong Signal Strength with the exception of WFXU that is Weak signal strength.
WFXU now has another Network.
That is why I recommend aim the ANT751 or HBU11k antennas at WFXU at about 335 degree magnetic compass direction.
The Tv stations to the , South West , South , South East , in the Green and Yellow reception zones are Strong Signal Strength and will be received by the ANT751 or HBU11K antennas , through the back angles and back of the ANT751 and HBU11k antennas.
Directional antennas such as and not limited to the ANT751 and HBU11K antennas.
Receive the best at the forward/front direction.
A little less at front angles to the antenna.
A little less at back angles to the antenna.
A little less at the back of the antenna.
And least amount of Tv signal directly on the sides of the antenna.
Places a little picture of the ANT751 or HBU11K antennas on the Tvfool radar plot aimed at WFXU and see that the Tv stations to the , South West , South , South East , are at back angles and back of the ANT751 or HBU11K antenna.
Last edited by teleview; 18-Mar-2014 at 11:49 PM. Reason: Clarify information and typos.
