Old 18-Mar-2014, 7:44 AM   #3
To receive Many Digital Broadcast Tv Stations/Channels.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , buy the roof and building in the directions of , North West , South South East , North East.
Install a ,
http://www.antennacraft.net.
HD1200 All channel antenna aimed at about 304 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , do not trust a cell phone compass.
Can also buy the HD1200 antenna at , http://www.amazon.com.
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch lengths of , TOP RAIL , chain link fence , PIPE , to use as antenna mast pipe , low price of about 10 dollars.
Install a ,
http://www.channelmasterstore.com.
CM3418 , 8 way distribution amplifier.
can also buy at , http://www.amazon.com
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
Multi-Path reflecting Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the HD1200 antenna at a location that has the amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 18-Mar-2014 at 11:39 PM. Reason: Clarify information and typos.
