WGBA-DT , Real UHF channel 41 (1-2) , virtual number (26.1-2) , NBC and CW is Very Weak Signal Strength at 1.7 NM(dB) and has 2 Edge Path=Hills/Mountains Obstructions.
WPNE-TV , Real UHF channel 42 (1-2-3) , virtual number(x) , PBS , is Very Weak Signal Strength at 7.6 NM(dB) and has 2 Edge Path= Hills/Mountains Obstructions
To see if signals strengths and reception conditions improve with higher antenna height.
Do not delete the first tvfool report at 25 feet antenna height.
Please make and post 2 more tvfool reception reports at 40 and 60 feet antenna height.
Reason: Clarify information and typos.
