Old 17-Mar-2014, 10:00 PM   #2
Install a.
ANT751 or ANT751R , both are the same antennas.
Or a Antenna Craft HBU11K antenna.
Above the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South West , South , South East , North.
Aim the antenna at about , 335 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antenna , Do not trust a cell phone compass.
A antenna system amplifier is Not required.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
http://www.amazon.com.
http://www.antennacraft.net
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect one Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Reception.
The Best Practice for Reliable Reception is install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv/s Must Channel Scan for the , OTA=Over The Air , ATSC-Digital Broadcast Tv Stations/Channels , often named the ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to your receiving antenna.
Some Digital Tuners will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select ~ Antenna Channels ~ ATSC Channels ~ DTV Channels ~ Air Channels.
Channel scan for ATSC-Digital Broadcast Tv Stations/Channels.
Last edited by teleview; 18-Mar-2014 at 7:48 AM. Reason: Clarify information and typos.
