Old 16-Mar-2014, 8:05 AM   #3
The best antenna is the antenna that is for your Receivable Digital Broadcast Tv Stations/Channels.
The antenna or antennas will be a antenna that is selected to keep Multi-Path at a Minimum for the Best Signal Quality.
And provides sufficient signal strength.
Please make and post a Tvfool Radar and Channel List Report.
Use the Exact address of the reception location to make the report.
Make the antenna height in the report 25 feet above ground.
A antenna height of 25 feet above ground is a Reference antenna height that provides a good initial evaluation of what is receivable.
