The Current Tv Channels that are being Transmitted and Received in the , USA , Canada , Mexico are.
UHF band channels 14 thru 51.
Your reception location has Tv channels in All 3 Tv Bands.
The HD850 is Made To Receive Tv Channels of All 3 Tv Bands.
The HD850 is a small antenna with a Wide beam width.
Does well at receiving Tv stations of other directions.
Directional antennas such as and not limited to the HD850.
Receive the best in the forward direction.
A little less at front angles to the antenna.
Less at back angles to the antenna.
Less at the back of the antenna.
And receive the least amount of signal directly on the sides of the antenna.
LOOK at the radar plot Of Receivable Tv Stations for your location , your location is in the center of the radar plot.
The TV stations in the Green and Yellow reception zones.
With the HD850 aimed at about 160 degree magnetic compass direction.
That is a in between aim direction between the 2 groups of Tv stations to the South East and South West and the Tv stations are at front angles to the antenna.
The Radar Plot shows W35CU-D UHF channel 35.
W35CU-D UHF Channel 35 is not transmitting.
If and when W35CU-D starts transmitting it is at a back angle to the antenna when the antenna is aimed at about 160 degree magnetic compass direction.
Reason: Clarify information and typos.
