Old 15-Mar-2014, 6:38 AM   #3
I recommend a 1 antenna solution.
For reception of the Canada and USA Digital Broadcast Tv Stations/Channels.
Install a , http://www.antennacraft.net.
HBU44 antenna above the roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , East , South East , South South West.
Aim the HBU44 antenna at about 157 degree magnetic compass direction.
A antenna system amplifier will most likely not be required for 1 or 2 Tv's connected.
The Antennacraft web site shows Canada sellers of Antenna Craft.
http://www.trentondistributors.com
http://www.saveandreplay.com
http://www.ronard.com.
Absorbing and Blocking Reception.
The Best Practices for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Digital Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
To clear tuner do Double Rescan.
http://www.wchstv.com/DoubleReScanAlert.pdf
Last edited by teleview; 16-Mar-2014 at 5:32 PM. Reason: Clarify information and typos.
