Old 14-Mar-2014, 9:48 AM   #2
As to the Leaf and other Magic Tv antennas.
The Magic Tv Antenna manufactures and sellers are retiring to a life of luxury.
I do not , manufacture , sell , recommend , and I am not a shill , for magic tv antennas.
So I live a simple life of my social security check and retirement check.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the roof and building in the directions of , South East , South West , West North West.
Install a , http://antennacraft.net.
HD850 , aimed at about 160 degree magnetic compass direction.
Install a , http://www.antennacraft.net.
10G201 preamplifier.
Install a , Leviton , model 47690-6 , 6 way splitter.
The 10G201 preamplifier , power supply / power injector , preamp unit , are all installed before the Leviton splitter input.
The Wireless internet can be put on a separate coax.
So the 5 Tv locations can be connected.
Or if the 4 outlets are to be connected , then use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-3D , splitter at , http://www.hollandelectronics.com , or , http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing and blocking Reception.
Multi-Path Reflecting Tv Signals Bouncing All Around
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
Last edited by teleview; 14-Mar-2014 at 9:37 PM. Reason: Clarify information and typos.
